My 1994 Suburban Power Windows
Old Dec 12, 2009 | 2:06 PM
mrc chevy's Avatar
Default My 1994 Suburban Power Windows
The Power Windows on the Drivers side sometimes work, sometimes don't work. Now they don't.
Yesterday the driver's side rear window wouldn't go down, then is was OK, but now both the front and rear Driver's side won't go down.
Would the problem be the entire switch assembly? A wire?
How do I pop that cover moulding off? The one that covers the switch area?
Thanks
Old Dec 12, 2009 | 4:42 PM
981500k's Avatar
The cover should be just cliped on but Im thinking you might have to take the panel off the door to access the switches wich would actually give you better access to the window motor, wires, etc. etc. one way to test it when the door skin is off is by giving it twelve volts directly wich wont hurt it as long as you dont prolong the time you use it that way
Old Dec 14, 2009 | 8:08 AM
T5258's Avatar
are they non-functional when using the master switch only, or does the left rear work with the switch on that door???
cnterline
40
Dec 9, 2021 11:48 AM
knarly gto
Jul 6, 2013 8:00 AM
spedaleden
Sep 11, 2011 2:03 PM
sidewayzpimpin
Jun 12, 2007 6:40 PM
n2whth2o
Nov 13, 2006 2:28 AM
