Is my alarm dead?
Old Sep 20, 2008 | 4:16 PM
BigPoppy's Avatar
Default Is my alarm dead?
Hi all,
I thought the FOB for my 1999 Suburban had died so I bought a new one. I've tried many time but can't get it or the original to take the program. Could the alarm module be dead? If so, does anyone have one to sell or can point me to one?
Thanks,
Bob
Old Sep 21, 2008 | 7:15 AM
jackyshaikh's Avatar
Default RE: Is my alarm dead?
Have you tried to program with this method? If not try this one
Transmitter Programming (Base)
[/align]
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
[ol]Ground pin4 to pin8 of the data link connector (DLC).
The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available).
The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation. [/ol][/align]
Old Sep 25, 2008 | 2:37 PM
BigPoppy's Avatar
That's the procedure I used but I get no lock cycle except when I perform grounding.
Old Sep 25, 2008 | 3:42 PM
I think there is some where problem in circuit,check below. [/align][/align]
Keyless Entry Does Not Program (Except Luxury) [/align][/align][/align][/align]
Step
Action
Value(s)
Yes
No
[ol]Disconnect the remote control door lock receiver connector.
Connect a DMM, set on ohms, between cavityL and the Data Link Connector (DLC) cavity8. [/ol]
Is there continuity?
Go to Step2
Go to Step3
Replace the remote control door lock receiver. Refer to Remote Control Door Lock Receiver Replacement .
Is the repair complete?
Go to Transmitter Programming
Repair open in CKT1455(BLK/WHT) between the remote control door lock receiver and the Data Link Connector (DLC). Refer to Wiring Repairs in Wiring Systems.
[/align]
Old Oct 20, 2008 | 8:22 AM
BigPoppy's Avatar
Sorry for my late reply, thanks I'll give that a try. It also appears that I have a bad door lock selonoid somwhere, the power locks only work with the starting and turning off of the motor.
Sergerancourt
Traverse
Dec 1, 2014 7:19 AM
knarva
Apr 13, 2013 7:23 AM
biglg
May 15, 2007 11:09 PM
