My truck
Old Jan 16, 2018 | 8:06 PM
Chaka Hicks's Avatar
Default My truck
I have a 2000 Chevy suburban it starts up fine but when you put it in drive or reverse it won't move. What could be the problem
Old Jan 17, 2018 | 8:17 AM
SabrToothSqrl's Avatar
Well... any error codes? or Check Engine Light?
I'd start with a possible transmission issue. When was the fluid last replaced? What's the current level?
Could also be the shift cable. I believe in 2000 there was still a metal cable connecting the shift lever to the trans. (vs. electronic). Does the truck roll when in D or R? If it feels like it's still stuck in park, maybe it's not actually shifting?
Old Jan 17, 2018 | 12:48 PM
The levels are full and when I put it in drive or reverse it doesn't roll move nothing
Old Jan 19, 2018 | 11:28 AM
Frank3's Avatar
My 2002 Tahoe had the clip that holds the shift cable on the linkage on the transmission fall/rot off. The lever moved at the steering column but never moved the linkage on the side of the transmission. If I remember correctly, when this happened, the **** indicator did not move when the lever was moved.
Old Jan 19, 2018 | 12:01 PM
That's my thought. something cable wise isnt' getting from the shift lever to the actual tranny. Which just means you're still in Park.
Old Jan 19, 2018 | 2:23 PM
It's just like the Bowden cable on a lawn mower throttle. If the cable housing isn't constrained then it will just move with the cable itself and not do any actuated.
