My truck
Well... any error codes? or Check Engine Light?
I'd start with a possible transmission issue. When was the fluid last replaced? What's the current level?
Could also be the shift cable. I believe in 2000 there was still a metal cable connecting the shift lever to the trans. (vs. electronic). Does the truck roll when in D or R? If it feels like it's still stuck in park, maybe it's not actually shifting?
My 2002 Tahoe had the clip that holds the shift cable on the linkage on the transmission fall/rot off. The lever moved at the steering column but never moved the linkage on the side of the transmission. If I remember correctly, when this happened, the **** indicator did not move when the lever was moved.
