Nav radio fan won't shut off
Old Feb 26, 2007 | 11:30 PM
genestoy's Avatar
Default Nav radio fan won't shut off
I just got done installing my new nav radio and have now noticed that the fan in the nav radio is still running (sounds like a whirring fan) after the truck being shut off for over two hours? I have just removed the neg battery cable as I thought the battery would finally go dead. Anybody know why this nav unit keeps running?
Thanks
Old Feb 27, 2007 | 12:28 AM
tahoe07's Avatar
Default RE: Nav radio fan won't shut off
Are you sure it's the fan? The CD spins up as soon as you open a door so the NAV will be ready.
Old Feb 27, 2007 | 12:37 AM
genestoy's Avatar
It still runs with me inside with the doors closed, it will not shut off. I don't really know if it is the fan or the disc motor spinning. There is no cd/dvd in the unit as I can not get it to do anything until it is flashed I assume as it is in the "Theft Lock" mode. I also have no sounds anywhere, no ding ding when the key is left in no turn signal noise, no horn chirps when locking with remote, etc.
Old Feb 27, 2007 | 1:53 PM
ZX1100F1's Avatar
Once you get the radio matched to your Tahoe it will act normally, don;t worry about the fan running, your battery can handle that load for weeks.
Old Feb 27, 2007 | 6:25 PM
genestoy's Avatar
So, are you saying that the re-program will then make the fan shut off? If not then I can not believe that something like that is running 24/7 inside the truck as it will run the battery down in time! Not to mention the wear on the internal parts of the radio ie the fan.
Old Feb 27, 2007 | 6:43 PM
konasmrz's Avatar
Put in the NAV DVD and it should stop once thedisc completesloading. This may take form 15>30 minutes the first time. You don't need to program the unit first. I've never had mine in for programming....... (unless yours was in another vehicle previously then you will have to get it out of theftlock)
Old Feb 27, 2007 | 6:52 PM
genestoy's Avatar
I would love to but can't get the door to open to put in the dvd? How do you do that when in "Theft Lock" mode?
Thanks
Edit: answered too fast - yes I need to get it re-programed first I assume.
Old Feb 28, 2007 | 11:55 PM
genestoy's Avatar
OK, here is the way it really works. You have the radio and the nav system on then shut the truck off and exit the truck, the radio disc/fan (don't know which or maybe both) continues to run for a couple of minutes presumably to cool everything down and then automatically shuts itself off. Whenever you enter the truck thru either door the units fan/disc starts running again before you even start the car and if the car is never started it shuts down again automatically.
nherweck
Nov 3, 2011 8:36 AM
Sub01
Dec 3, 2007 7:46 PM
hexman512
Dec 29, 2006 10:23 PM
