Nav radio and XM
Old Aug 16, 2006 | 1:03 PM
davemec
Guest
Posts: n/a
Default Nav radio and XM
Anyone have success removing XM categories? I tried doing this under the menu option, when I remove a category the category dims, but when I scroll through the categories on the radio using the left and right arrows beside the category, they all still show up. Is this menu option supposed to remove them from this interface or from somewhere else?
Old Aug 16, 2006 | 2:21 PM
sjenkinzz's Avatar
Default RE: Nav radio and XM
I have not tried to remove a catagory myself, but I will try tonight and see what happens.
Old Aug 24, 2006 | 6:07 PM
MEVtopsail's Avatar
I have talked to the local 07 chevy rep, and he had said that gm knows about the problem, but he said the same thing....it does not work
Old Aug 28, 2006 | 1:46 PM
davemec
Guest
Posts: n/a
Thanks for the info, hopefully they will find a fix for this.
Old Aug 28, 2006 | 1:51 PM
funky_junk's Avatar
ORIGINAL: davemec
I removed a few from mine this morning and it worked fine for me.
Old Aug 28, 2006 | 2:02 PM
davemec
Guest
Posts: n/a
funky_junk, after you removed them, did you scroll through the categories when back in the audio tab?
Old Aug 28, 2006 | 2:07 PM
ZX1100F1's Avatar
Some of the older 07 units had this problem; there is currently an AMR update available through the dealership service dept.
The AMR update is a disk that the dealer orders through GM, they install this into your unit and it reflashed a new firmware update to correct this and several other problems that have been identified.
If your dealer doesn't have the disk yet, ask them to order it.
Old Aug 28, 2006 | 2:12 PM
funky_junk's Avatar
ORIGINAL: davemec
Don't remember. I will try again when I run out and let you know.
cjasonsmith
Feb 21, 2009 10:50 PM
adamant
Feb 15, 2009 8:49 AM
guvner
Nov 4, 2007 8:37 AM
sharky35
Jun 3, 2007 2:22 PM
