Nav unit install help please
Old Oct 15, 2008 | 10:13 PM
epagidas's Avatar
Default Nav unit install help please
OK I know this has been covered here and I'veread through all of the past threads on installing a NAV/DVD radio.
[ul][*]I have a NAV/DVD radio w/bose out of a 07' Suburban coming to me[*]I am installing it intomy 08' Silverado that also has Bose[*]So it should be a lot easier because I don't have to mess with any amps.[*]I know that I need to install the GPS antenna[*]I know that I need to have it unlocked[/ul]
Here are the questions I need answered:
[ol][*]I know about the VSS wire but I hear that JP Customs is no longer in business. Can this be done without their harness? If so how?[*]I know about theVCIM (onstar) for voice recognition. How do I tie into this?[*]Anyone know a source for the GPS antenna cheap?[/ol]
Am I missing anything?
Thanks,
Steve
Old Oct 18, 2008 | 2:00 PM
epagidas's Avatar
Default RE: Nav unit install help please
Can anyone help with my questions?
Old Oct 19, 2008 | 5:17 PM
shawnvw's Avatar
Banned
Go to a GM dealer for the antenna..its only about $20. The VSS needs to have a pin inserted into the radio connector and it must be the right pin. Same goes with the voice recognition....the harness that you get, has a connector on one side to plug into the VCIM, and the other side has a couple leads that you have to pin into the radio harness. If you go to a dealer, they can get the parts for you and build it.
You don't need to do the voice recognition harnessthough, the nav will work fine without it, you just won't be able to use voice commands
Old Oct 19, 2008 | 9:22 PM
epagidas's Avatar
So if I understand you correctly you are saying that pin 5 on the 16-pin connector C4, needs to be jumped to the VSS wire located in the body control module (BCM)???
16-Pin Connector C4:
Pin Wire Color Circuit No. Function
1 Not Used
2 Not Used
3 D-BU 6760 Center Channel Low Level Audio Signal (UQS)
4 WH 6763 Subwoofer Low Level Audio Signal (UQS)
5 D-GN/WH 817 Vehicle Speed Signal (UVC)
6 PK 6972 Camera Signal #2 + (UVC)
7 L-BU 6973 Camera Signal #2 (UVC)
8 PU 5837 Amplifier Audio Prompt Signal (+) (UQS)
9 Not Used
10 Not Used
11 OG 6761 Center Channel Low Level Audio Signal (-) (UQS)
12 PK 6762 Subwoofer Low Level Audio (-) (UQS)
13 Bare 6759 Drain Wire (UQS)
14 Not Used
15 Bare 5838 Drain Wire (UQS)
16 GY 5836 Amplifier Audio Prompt Signal (-) (UQS)
Do you know where the VCIM pins are?
14-Pin Connector C1:
1 RD/WH 340 Battery Positive Voltage
2 TN 201 Left Front Speaker Output (+) (UQ3)
TN 511 Left Front Low Level Audio Signal (+) (UQA/UQS)
3 L-GN 200 Right Front Speaker Output (+) (UQ3)
L-GN/WH 512 Right Front Low Level Audio Signal (+) (UQA/UQS)
4 PK 5149 Voice Recognition Audio Signal (UE1)
5 PK/BK 5152 Low Reference (UE1)
6 WH 7066 Entertainment Remote Enable Signal
7 YE 6817 LED Backlight Dimming Control
8 BK 2550 Ground
9 GY 118 Left Front Speaker Output (-) (UQ3)
D-GN 1947 Left Front Low Level Audio Signal (-) (UQA/UQS)
10 D-GN 117 Right Front Speaker Output (-) (UQ3)
OG/BK 1546 Front Low Level Audio Signal (-) (UQA/UQS)
11 Bare 2011 Drain Wire (UQA/UQS)
12 Not Used
13 D-GN 5060 Low Speed GMLAN Serial Data
14 Not Used
16-Pin Connector C2:
1 BN/WH 367 Remote Radio Left Audio Signal (U2K)
2 D-GN/WH 368 Remote Radio Right Audio Signal (U2K)
3 Bare 2099 Drain Wire (UQA/UQS/UK6)
4 L-GN 7396 DVD Video Signal 2 (+) (DNU)
5 BN 199 Left Rear Speaker Output (+) (UQ3)
BN/WH 599 Left Rear Low Level Audio Signal (+) (UQA/UQS)
6 D-BU 46 Right Rear Speaker Output (+) (UQ3)
D-BU 546 Right Rear Low Level Audio Signal (+) (UQA/UQS)
7 D-BU 658 Cellular Telephone Voice Signal (UE1)
8 OG 6978 Amplifier Control (UQA Except Y91)
9 TN/WH 372 Remote Radio Audio Output (-) (U2K)
10 GY 388 Remote Radio Right Audio Signal (U2K)
11 Bare 1573 Drain Wire (U2K)
12 WH 7394 DVD Video Signal 2 (-) (DNU)
13 YE 116 Left Rear Speaker Output (-) (UQ3)
BN 1999 Left Rear Low Level Audio Signal (-) (UQA/UQS)
14 L-BU 115 Right Rear Speaker Output (-) (UQ3)
TN 1946 Right Rear Low Level Audio Signal (-) (UQA/UQS)
15 L-BU/BK 659 Low Reference (UE1)
16 D-GN/WH 7395 Video Mode 2 Signal (DNU)
16-Pin Connector C3:
1 YE 2059 Auxiliary Audio Left Signal
2 WH 2058 Auxiliary Audio Right Signal
3 L-BU 5826 Left DVD Audio Signal (+)
4 WH 5828 Right DVD Audio Signal (+)
5 OG/BK 5831 Remote Infra Red Signal (+)
6 PK/BK 5844 Video Bright Control
7 D-GN 6975 DVD Video Signal (+)
8 PU 2056 Auxiliary Video High Signal
9 Bare 5345 Drain Wire
10 L-GN/BK 5845 Video Module Signal
11 PU 6979 DVD Audio Common
12 Bare 6980 DVD Audio Shield
13 TN/WH 5830 Remote Infra Red Signal (-)
14 Bare 6976 DVD Video Drain Wire
15 WH/BK 5335 DVD Video Signal (-)
16 Bare 5346 Video Drain Wire
Old Nov 20, 2008 | 9:43 AM
epagidas's Avatar
Can anyone help me some more on this?
Shawnvw can you possibly answer my questions in the last reply above?
Old Nov 20, 2008 | 6:08 PM
shawnvw's Avatar
Banned
VSS goes to pin 5 of the brown connector at the radio, and connects to the back of the junction box uder the drivers side of the dash. It goes to a green\white wire in the big connector on the bottom
Here is a schematic for the onstar mic
bigkickr
Aug 27, 2012 9:52 AM
fishfreak
Dec 21, 2010 11:25 PM
cmonteiro1
Jan 8, 2009 9:32 PM
epagidas
Sep 28, 2008 6:49 AM
pat130
Jun 11, 2007 5:00 PM
