navi install in a non-Bose system
Not sure if your still on the site VanDamme but i could use some help installing my Bose Navigation into my non Bose Avalanche. I'm i correct in assuming that all i need is the Navigation unit & Disc, VSS Wire, PAC, GPS Antenna, and an aftermarket amp?
I too Have installed a GM Nav unit in a Non-BOSE car, 2007 Acadia, the Donor car was a 07 Acadia W/the GPS antenna no VSS wire used yet. The Unit works fine,after GM Tech programming to unlock the unit, But the Nav Pomp Volume it is not loud enough, it dose go softer to louder but when the car is in use you can't hear it, I am thinking I need the GM Non AMP kit? Also I have noticed the Warning Chimes do not work now i.e. Seat belt not buckled, light works but no chime as well as the Lights left on.... Can anyone HELP?
rahb0sse
May 2, 2011 12:06 AM
Molodtsoff
Jul 13, 2010 8:56 AM
fakhir1234
Feb 27, 2009 7:41 PM
