Navigation Compass Innaccurate- Help!!
On a 2010 GM navigation unit, after being installed and unlocked at the dealer the compass does not work. The arrow on the screen does not rotate as the truck moves. It only points as if the truck is moving east.
Any suggestions???
Any suggestions???
There are three modes, North is always at the top, direction truck is going is always on top, and the 3D mode where North is on top.
You change by pressing on the icon in the upper left corner. Don't know if that will help.
Tricia, GM Customer Service.
I am having the exact same problem on 2011 Tahoe. The GM navigation unit was installed and unlocked at the dealer. The unit works fine with the exception that the compass does not work. The arrow on the screen does not rotate as the truck moves. It only points as if the truck is moving east.
Any suggestions???
<!-- / message -->
Any suggestions???
<!-- / message -->
The person who this happend to said he took in into a stereo shop and they had to weld a piece inside back together and everything worked fine after that. He did not elaborate as too what part he had to weld back together.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> dgarcia968,
I am not currently showing any known navigation issues with Tahoe vehicles within my resources. Have you taken the vehicle in for an inspection? Your vehicle is still under warranty, correct? If you would like, I can investigate your vehicle further, if you PM me your VIN number.
I look forward to your response.
Louis
GM Customer Service
Louis
GM Customer Service
