Need Help!! 2004 Sub electrical issue
Old Oct 17, 2013 | 6:39 PM
Warmstrong's Avatar
Exclamation Need Help!! 2004 Sub electrical issue
I have an 04 1500 suburban that runs the battery completely dead every evening. I also get an intermittent service airbag in the DIC. If I remove the MBEC 50 amp fuse in the engine compartment fuse box, the vehicle doesn't bleed the battery, but all the pass side door and seat functions don't work. When I put a code reader on it, I found two stored codes; C0292 and C0196. Any help troubleshooting this issue would be greatly appreciated.
Old Oct 20, 2013 | 12:02 PM
scoutski's Avatar
It could be somthing in the alternator that is causing the drain. Just a guess as I do not know what circuits that fuse controls.
Old Oct 20, 2013 | 3:03 PM
I believe both those codes have to do with the steering wheel position or sensor..
bkscott1987
Nov 13, 2020 2:42 PM
cableguy83
Jul 15, 2012 2:37 PM
yuki_ookami
Nov 26, 2011 9:16 PM
trailblazer06
Feb 20, 2009 4:09 PM
davinnyjk09
Dec 12, 2008 11:43 PM
