Need help with 97 suburban tick
Old Nov 30, 2009 | 9:03 PM
travisd's Avatar
Default Need help with 97 suburban tick
Our '97 Sub has a top end tick after being started when cold. After a couple of minutes of idling it will go away. I'm assuming it's lifter noise that is quieted after some oil flow and am wondering how big of a fix this is or if anyone has another source for info. It's the 5.7.
Thanks in advance.
Old Dec 1, 2009 | 11:35 AM
Captain Planet's Avatar
My 2000 Suburban does the same thing however my engine is the 5.3. I know my engine is known for "pison slap", extra space between the piston and the cylinder wall. I hadn't heard about this problem with the 5.7.
Old Dec 1, 2009 | 6:39 PM
WilliamM4202006's Avatar
I had a 99 Tahoe with the 5.7 and it did the same thing. The day after I bought it it started doing it. I brought it back and they had to put all new lifters in it. I always thoguht the 350 was bullet proof. Every since it always did it or made a knocking noise when first started. Well I totaled that one about a onth ago and bought an 01 Tahoe, which has the motor noise at start up. I heard all the 5.3's till 2004 did it till they corrected it. they say it doesn't hurt anything but sometimes i wonder when I hear some of them.
Old Dec 1, 2009 | 8:51 PM
MDTAHOE's Avatar
Professional Mechanic
If it lasts more than a few seconds it is not normal (less than 5). You can try finding a shop that has the newest BG oil flush chemical and machine www.bgfindashop.com I have seen THIS machine take care of several lifter noises. You can also try a quart of Lucas oil treatment.
Old Dec 5, 2009 | 9:42 AM
I wish I knew about that machine when I had my 99. It only did it for a couple seconds but before they changed the lifters it would do it for a long time..My 01 only does it for a couple seconds...Do you think that machine would make it go away. Prob not though huh considering all 5.3s do it till they corrected it...
Old Dec 6, 2009 | 12:21 AM
bouncerboy87's Avatar
Finally another Tahoe that has "The Noise" I too have found out that the noise can raise concerns but I added a Lucas Oil treatment It quieted the noise considerably altho it doesn't beat the noises coming from a 2000 dodge ram 2500 it was like vietnam all kinds of ticking and grinding and creaking.
Old Dec 6, 2009 | 8:13 AM
mudmaniac's Avatar
Ride of the Month
May 2009
My wife's 03 Tahoe does it as well, sometimes for about 30 seconds.
Old Dec 6, 2009 | 4:36 PM
travisd's Avatar
I hear you with the Lucas Oil Treatment, how about Seafoam? I'm a firm believer in their Transtune product, but have not tried their Engine Restorer.
treefrogjeff
Dec 28, 2017 10:25 AM
tsduke
19
Apr 29, 2010 1:20 PM
07SSport
Sep 22, 2009 8:28 AM
travisnewberry
Jan 7, 2007 11:08 PM
