Need help with a code 42 on a 91 Surburban
Old Mar 31, 2021 | 9:48 AM
Ammo Pete's Avatar
Default Need help with a code 42 on a 91 Surburban
Need help code 42 1991 Surburban R1500 5.7
I did a tune up and crossed a couple wires and moved it out of time. When fixing the issues I was setting the timing and unplugged,one at a time, the 2 sets of wires coming out of the back of the distributor when I couldn’t find the black tan one. I found the tan and black later when adjusting. Afterwards I got a code 42. I replaced the distributor and timed it and still have the code 42. It runs strong but smells ritch and isn’t 100% like before. How do I fix? Thanks
Old Apr 6, 2021 | 3:45 PM
TrentC's Avatar
This is what I found
ODE 42 - Electronic Spark Timing or Bypass Fault
Trouble Code 42 indicates that there may be a malfunction in the Electronic Spark Timing (EST) system.
During cranking, the timing is controlled by the ignition module while the ECM monitors the engine speed. When the engine speed exceeds 400 RPM, the ECM sends a BYPASS signal to the ignition module which switches the timing to ECM control. The ECM calculates what the timing should be then "tells" the ignition module via the EST circuit.
An open or ground in the EST circuit will stall the engine and set a Code 42. The engine can be re-started but it will run on ignition module timing.
Maybe double check those wires again
Ammo Pete
Mar 30, 2021 12:16 PM
sven556
Dec 6, 2015 9:05 PM
Cpollock
Apr 7, 2012 12:22 AM
daddyd01
Jun 5, 2011 11:18 PM
