need help fast thx
Old May 16, 2007 | 8:50 PM
99tahoe5.7's Avatar
Default need help fast thx
i own a 1999 tahoe 4 door 4x4, they have 4 spkrs in all 4 drs n 2 spkrs in the trunk space, the issue is that the spkrs in the back doors dont work, anybody have n e idea why besides thinkin that the spkrs r blown
Old May 17, 2007 | 1:57 PM
ZX1100F1's Avatar
Default RE: need help fast thx
Check fader on radio making sure that it is either centered are full to rear.
Remove speaker(s) and use voltmeter to check wire for power to speakers (with volume up) if you get power then replace speakers if you don't get power then test for continuity from the wire harness at the head unit to the speakers if no continuity then track down short in speaker wires (usually at rear door pass through), if good continuity then replace head unit or have it repaired.
Old May 20, 2007 | 2:30 AM
99tahoe5.7's Avatar
thanks for ur input, ima try and see this week what the problem is....or i could just leave it the way it is because i willbe installing a few amps into my truck and to the back door speakers that arent working i could just connect the amp str8 2 those speakers
Old May 20, 2007 | 2:31 AM
99tahoe5.7's Avatar
im about 2 purchase rims for my truck, i kno i will be safe with 305 45 22 sets but how about 305 35 24, will 24 inch rims mess up my suspension>
chevyman1981
Feb 9, 2010 11:51 AM
deejayrock
Sep 20, 2007 1:07 PM
deejayrock
Feb 16, 2007 4:16 PM
superburban
Oct 27, 2006 11:12 AM
dochou
Aug 30, 2006 2:49 AM
