need help with power
Old Apr 14, 2007 | 3:15 AM
dmicgrif's Avatar
Default need help with power
just bought a 98 4door. put glass pack duel exhaust on, sounds great but i thought i would have more power. should i get a intake or is there something else out there that will help with the power.and withthrottle body spacer do those really help or hurt the engine?
Old Apr 14, 2007 | 2:46 PM
ZX1100F1's Avatar
Default RE: need help with power
Most go-fast goodies do little (to nothing) to actually increase power across the RPM scale, and the ones that do enhance power usually rob Peter to Pay Paul; that is: they move power from low RPM ranges to higher RPM ranges where you rarely run the truck.
My first thought if you're working on an on older (1998) is that the truck probably has some miles in it and could probably benefit from an overhaul, once inside you can do a few things that will actually help out such as a port and polish, a roller cam, bump the compression and bore out the cylinders and things such as this.
Old Apr 14, 2007 | 9:29 PM
dmicgrif's Avatar
my truck only has 65000 miles some what low.
Old Apr 14, 2007 | 10:00 PM
ZX1100F1's Avatar
That is low, install a supercharger and keep the boost under 6psi.
Old Apr 15, 2007 | 12:23 AM
engine2's Avatar
ORIGINAL: ZX1100F1
I agree with ZX on his recommendations.
Also, the programmers offered by various manufacturers really shine in diesels, but are not really worth it in gasoline powered engines. I would only get one if you were reprogramming for aftermarket wheels.
Another note. I put a big diameter exhaust on a mid nineties 5.7 V8 Chevy and actually lost power because I had little back pressure.
Old Apr 16, 2007 | 2:46 PM
dmicgrif's Avatar
would love to get a supercharge, but the coast guard does not pay a whole lot. so i have to save over the summer.
upzaw2000
HHR
Apr 5, 2022 9:22 AM
hunter10220
May 18, 2011 8:37 PM
Blazer311
K5 Blazer
Jul 26, 2007 6:53 PM
upzaw2000
HHR
Dec 30, 2006 12:58 PM
