need help! suburban not starting after
Old May 31, 2013 | 8:30 PM
besto's Avatar
Default need help! suburban not starting after
Hello everyone.
In the process of repairing one of my suburbans I damages my running suburban.
I have 2 suburbans
one is a 96 1500 2x4
2nd is 99 1500 4x4
My 99 suburban failed and to rule out the ecm(ECU) as the problem, i removed the ecm and plugged it into my 96 suburban
The 99 suburban ecu in my 96 suburban did not start the truck.
It just sputtered and smoked out of the intake pipe (grey/Powder color)
I immediately removed the ecu and re-installed the factory working 96 ecm.
I was expecting the truck to start up but it just cranks over.
Now its dead and wont start.
my question is what component did I burn out if any?
The truck was running fine minutes before i swapped the ecm
I have checked for codes none back.
Checked spark and replaced spark plugs with a fresh set
fuel pressure is at 60 -
Could I have damaged the spider injectors or the distributor and cps?
Any help is appreciated.
Thank you!
lowlyneo
Oct 25, 2013 7:33 AM
drmartin
Mar 22, 2010 9:26 AM
keelklan
Jun 9, 2009 10:53 AM
