Need opinions on 2007 Suburban, 2007 Tahoe, and 2005 Avalanche
Old Sep 14, 2022 | 9:26 PM
HyperspaceExplorer's Avatar
Default Need opinions on 2007 Suburban, 2007 Tahoe, and 2005 Avalanche
  • Does the Suburban really have that big turning radius and difficulty of parking the vehicle? I have seen one and it looks normal; it did not look quite as big other people describes it. For reference, I see a full size Desert Eagle pistol as "small" that shocked my younger brother's late friend when he showed his Desert Eagle pistol.
  • How big is the turning radius, in your experience, of the 2007 Suburban compared to the 2007 Tahoe and 2007 Avalanche?
  • Is a rear-ended 2007, no airbag was deployed, Tahoe LTZ with "minor" damage, per Autocheck, still a good buy? This one was from Idaho then went to Florida where it got the accident then here to California being sold.
  • Is the 2009 Tahoe has significant improvement over the 2007?
  • Is the 2005 Avalanche prone to rust and rot? I have seen YouTube videos on it and the rust looked bad.
  • Does the Avalanche really have an optional tow package at the time? The dealer noted the 2005 Avalanche they are selling has a tow package.
  • Is loading a motorcycle cruiser, around 650 lbs, on the Avalanche's bed doable and safely be transported?
2007 Suburban is 2WD I suppose since it is LS trim.
2005 Avalanche is 2WD
2007 Tahoe is 4WD
Thank you.
EDIT: I don't have a garage so vehicle will be street parked.
Old Sep 14, 2022 | 10:26 PM
Kenrbass's Avatar
The best answer is, it depends. Pick the best condition with lowest mileage you can find. All things equal, 07 was a problem year for gm. It was first generation cylinder deactivation. You may have set the record for the most questions in one post.
Old Sep 15, 2022 | 9:23 AM
repairman54's Avatar
Avalanche bed is not big enough for a big bike. Not to mention getting a big heavy bike up that high in the air and getting it off safely.
3 state vehicle means it was more than likely a salvage and moved around to different states to get the salvage off the title. Happens a lot as it's easy to do in a lot of states.
Statman
Apr 28, 2017 9:29 AM
Hulln1
Nov 12, 2014 4:28 PM
ZX1100F1
Sep 28, 2007 1:40 PM
mikem
Avalanche
Aug 8, 2006 4:28 PM
92chevyhamp
Avalanche
Aug 8, 2006 4:21 PM
