New to the forum, got some questions..
Old Nov 9, 2014 | 10:39 AM
  #11
Originally Posted by mikepresson
I'm now getting power to everything again. I was testing my fuse panel and found no power to the ignition fuse. I used a jumper wire and am now getting power to my ignition fuse. The fuel pump now comes on but truck still wouldn't crank. I did some more investigation and found the crank fuse has no power going to it, so I used another jumper wire to the crank fuse and am now getting power to the crank fuse. I pressed down the clutch and the truck cranked right up. The key isn't even in the ignition. I press the clutch again and it grinds the starter. The clutch is acting as my ignition now what do I do?? I'm lost.
You need to get to the root of why those fuses had no power, you know the circuits work if you jumper them so that is a good thing... I suspect you have an ignition switch issue...
Ryan Brickel
May 25, 2012 4:06 PM
xntech
Aug 26, 2011 11:21 AM
smittyman
Aug 17, 2009 9:33 PM
wjxavier
May 12, 2009 3:34 AM
sandlercd_22
Jan 5, 2008 9:33 PM
