New to forum with a question
Old Jul 5, 2015 | 9:55 AM
Schoolcop's Avatar
Default New to forum with a question
Hello and thanks for the add. I recently purchased a 2008 Suburban Ltz with 131,000 miles on it. I plan on changing the transmission and transfer case fluids soon and also switching to a synthetic engine oil. Can someone tell me if it's worth the extra expense to go with the synthetic. Thanks,Randy
Old Jul 5, 2015 | 10:13 AM
TMcWeed's Avatar
I had issues with several of my older vehicles and switched to synthetics and have sworn by them ever since. I use Amsoil but there are many quality synthetic out there. I now use synthetics in all my motorized vehicles for all applications.I was informed by a top ranked diesel shop that with diesels be sure you use an engine oil specifically designed for use in diesel engines as it can cause engine damage down the road.
Old Jul 5, 2015 | 10:31 AM
Schoolcop: Welcome to the forum.
TMcWeed: I agree on diesel oil. My MB Sprinter RV specifies Mobil 1 ESP among others and it runs about$8 to $10 a quart.
Old Jul 5, 2015 | 5:29 PM
Schoolcop's Avatar
Would you recommend synthetics for the other fluids also.
Old Jul 7, 2015 | 12:51 AM
justimagination's Avatar
Thumbs up
Schoolcop, a warm welcome to the forum, it's definately worth the switch, synthetic oil has been tested and proven to offer better COLD STARTUP protection as well CONTINIOUS operation in extreme heat. It costs more for better protection, especially over 100k mile vehicle. MOBILE 1 in my vehicles(oil only) transmissions are doing fine w/standard fluid. JMHO.
David g.
Old Jul 10, 2015 | 7:35 AM
{tpc}'s Avatar
I usually run the dexos stuff. Dealer close by does the change with that stuff pretty cheap now, so really no cost savings. I believe any other fluid you will change will already be a synthetic.
I'm not sure how the layout of the burb is vs the hoe, but you may want to save yourself the headache and have the dealer do the trans for you. The diff's and transfer case are EASY by comparison.
Also be sure what fluid you need for the transfer case. Some of the newer vehicles use dex vi in them I think, but my '07 uses the auto trac stuff. Your '08 may use it as well. If it does, save yourself the hassle of looking for it, you have to get it at the dealer.
But double check your owners manual so you know what to put back in.
Old Jul 10, 2015 | 10:50 AM
Scotiapilot's Avatar
Welcome and yes it is. Most people hear a difference, it's quieter. Noise is energy and heat.
navarro
Oct 20, 2012 10:20 PM
DG_Boomer
Site Feedback
Sep 1, 2009 9:09 AM
spyk3
Mar 8, 2009 12:08 AM
Zeo763k
Dec 11, 2007 1:43 PM
cutiger95
Mar 6, 2007 1:57 PM
