New member needing help brainstorming
Old Oct 24, 2011 | 5:48 PM
millenium3's Avatar
Default New member needing help brainstorming
Hello all,
Need some help. Just replaced the knock sensors on my 2003 Tahoe 5.3l. While completing the project i go to start the truck and it won't turn over. I noticed some fuel spitting from the fuel rail on the right side of the engine so I replaced the o-ring and it has stopped leaking. I was thinking I didn't connect something but I have gone over the engine a hundred times with no luck. If I had to guess I would say there is a fuel issue because it cranks but just won't turn over.
Any Ideas? thanks in advace!
Joe
Old Oct 24, 2011 | 6:11 PM
kevinkpk's Avatar
Project? What has been done?
Old Oct 24, 2011 | 7:31 PM
millenium3's Avatar
The "project" was the knock sensors and manifold gasket replacement. Apon completing, the truck wouldn't start. Since then I have gotten it started but it now runs horrible and idles sluggish and wants to stall. When I remove the vacuum line to the fuel pressure regulator it seems to go to a normal idle for a moment before going to a higher RPM. I am not thinking the diaphram is torn and Fuel Press Regulator needs to be replaced.
Any Ideas anyone???
Joe
Old Oct 24, 2011 | 7:48 PM
kevinkpk's Avatar
Any Ideas anyone???
Joe
My EXPERIENCE with a fuel regulator is LOW idle speeds. I'ts about a $40-50 item easy to change.
Old Oct 25, 2011 | 3:06 PM
millenium3's Avatar
ok, got it running good turns out both o-rings needed to be replaced on both sides of the fuel rails. now just have to solve my code P1518 problem!
Old Oct 25, 2011 | 3:17 PM
kevinkpk's Avatar
That code has to do with throttle control missing data. Reset the ecm. See if it goes away. I wouldn't be surprised if that had to do with the O ring problem.
Old Oct 25, 2011 | 3:22 PM
millenium3's Avatar
I reset to code and it has yet to come back although there is a decent in RPMs when I am at idle. Usually it idles around 1k-1 1/2k RPMs when idling but now it ranges from 5-800. everything seems normal though, just a really low idle RPM.
Old Oct 25, 2011 | 4:00 PM
kevinkpk's Avatar
Idle should be around 800. As I stated earlier MY experience with a fuel regulator is low idle such as 4-500. If there is still an issue it will come back.
Cyntthia Johnson
Dec 1, 2012 8:38 PM
hooligan332
Jun 1, 2011 5:38 PM
Gooseward
Oct 7, 2010 2:03 AM
justin.hughes
Jun 20, 2007 11:49 PM
