no 4x4
Old Nov 6, 2011 | 5:42 PM
deerdog1's Avatar
Default no 4x4
i have a 1999 tahoe. no 4 wheel drive.when i push the 4hi button it will blink a couple of times then remain steady but no 4x4. when in 2hi the front drive shaft will turn free when i hit the 4hi button it will not turn seems to be engaged but no 4x4 just rear wheel drive. what do you think encoder motor problem?
Old Nov 7, 2011 | 11:49 PM
maxxman04's Avatar
could be encoder, could be actuator at front diff. however, if the driveline locks in, then i would rule out the encoder. for the most part anyway. gm's are notorious for having the actuator on the front axle go bad. most parts stores carry, about $75-$100. really easy to change.
Old Nov 14, 2011 | 10:13 AM
deerdog1's Avatar
front actuator works,replaced the transfer case motor all fuses good still no 4x4 any ideas?
technicauto
May 4, 2011 5:14 PM
chevyman1978
May 1, 2008 6:41 AM
cowboyfromhell
Jun 5, 2007 9:31 AM
partsfor24
Apr 18, 2007 3:55 AM
