No hot air from driver side vents - yukon 07
Old Sep 11, 2011 | 5:53 PM
digitalgeek's Avatar
Default No hot air from driver side vents - yukon 07
Hi all,
I have a yukon 07 and it has trizone climate control. AC works fine in all zones, heater (hot air) works fine on the passenger side and rear AUX. However, I get no hot air form the driver side, the air temperature is the same as the outside
Any thoughts on this? is this a controller issue? any recommendations?
Thanks for you help in advance.
Old Sep 12, 2011 | 10:44 AM
SWHouston's Avatar
Possibly it is a malfunctioning Air Door Actuator.
It looks like this...
On Tri-Air, it is one of four that operate the flows.
IF you can find it under the Dash, try to turn the
shaft by hand, and it may break loose and turn.
If so, then you probably need to replace it.
(About $80 Dealer)
Sorry, I just don't know where under the Dash to
tell you to look on a 07 Yuke.
Possibility 2:
It may be that the Air Door is warped/stuck.
Once having disconnected the Actuator, you
can operate the door manually, rotate it back
and forth, and see if it is sticking.
Then go from there.
Old Sep 12, 2011 | 11:08 AM
(About $80 Dealer)
Possibility 2:
Then go from there.
If the door is malfunctioning, shouldn't that stop air form coming our completely? of is it the door the controls that air temperature?
Old Sep 12, 2011 | 11:19 AM
SWHouston's Avatar
d'geek,
I wish I could tell you absolutely, but designs vary from model to model.
I doubt very seriously that it is a go/no go, as in start/stopping the flow, but, an either/or, as in the choice of sources. Appears that it is selecting fresh air rather than conditioned.
Old Sep 15, 2011 | 4:05 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Digitalgeek,
Have you contacted the dealership? I recommend talking to them and seeing what they say. They will be able to diagnose and resolve the issue for you. Let me know how it goes there.
Breanne
Chevrolet Customer Service
driverstefan
May 3, 2019 11:09 AM
Beebe
May 3, 2019 7:37 AM
jricard
May 19, 2013 12:39 AM
EdZilla
Aug 7, 2006 1:26 AM
