No rear heat
Old Jan 13, 2008 | 4:36 PM
jonbert's Avatar
Default No rear heat
I have no rear heat blowing out of the rear roof heat vents. Any ideas?
Old Jan 13, 2008 | 5:52 PM
RonH's Avatar
Default RE: No rear heat
There's a valve at the rear blower unit that controls the flow of coolant through the rear system. It it's stuck closed, you will get air blowing, but no heat. There can be other causes, but the valve is a starting point of things to check.
Old Jan 13, 2008 | 6:07 PM
jonbert's Avatar
Thanks for the reply. Where is that unit located?
Old Jan 14, 2008 | 2:54 PM
RonH's Avatar
The auxiliary (rear) HVAC unit is located under the passenger side trim panel over the rear wheel. Remove the trim panel. Looking at the assembly, you will see the blower motor near the rear of the unit. Just in front of the blower motor and attached with screws to the ducting is the auxiliary temperature actuator. It has a wiring harness that plugs into a recepticle just in front of and next to the blower motor. It's this actuator that Ithink you should check.
Old Jan 16, 2008 | 8:10 PM
jonbert's Avatar
I got it off, turned the **** by hand and got heat. Trouble is, places like RockAuto.com claim I need part #640100 (according to GM for a 05 Tahoe) but says confirm the pin configuration first. It is different than mine. 640100 pin configuration looks like (.... )but Part # 640101 has a configuration of (.. ...) which is the same as mine and otherwise looks identical. They said I should check with a dealer. What do you think? Thanks,
John
Old Jan 17, 2008 | 12:32 PM
gxu3936's Avatar
Does anyone know if the rear HVAC unit is located in the same location (passenger side trim panel over the wheel) on a 2006 Tahoe as well? My dad's Tahoe is having the same problem as described here as well.
Old Jan 17, 2008 | 12:47 PM
gxu3936's Avatar
Correction, I mean a 2005?
Old Jan 17, 2008 | 2:12 PM
jonbert's Avatar
Mine is a 2005 Z71. And it is under the passenger side rear tirewell panel. If you turn the rear fan on high you can hear it and there is an output vent there.
Old Jan 17, 2008 | 3:23 PM
gxu3936's Avatar
Excellent - Thank you! I'll take a look and see what I can find.
RHYS
Uplander
15
Dec 28, 2021 8:25 AM
Chevmann92
Jan 3, 2014 2:03 AM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
