No spark
Old Feb 7, 2015 | 7:49 AM
Maxmania64's Avatar
Default No spark
I have replaced distributor, cap, rotor, coil, module, crankshaft position sensor, all plugs and wires. I have no spark. Please help
Old Feb 7, 2015 | 9:07 AM
year, model, engine?
with a scan tool; any ckps signal when the engine is cranked?
any theft lights on?
Old Feb 8, 2015 | 4:28 AM
Maxmania64's Avatar
96 suburban k2500 5.7 vortec.
No theft lights
Scan tool reading 0 rpms
Replaced ckps twice, still reads 0 rpms
Old Feb 8, 2015 | 8:48 AM
any dtc's set?
any camshaft position sensor signal?
have you checked the under hood fuse box; ecm 1 fuse that feeds both cam and crank sensors?
Old Feb 9, 2015 | 5:06 AM
Maxmania64's Avatar
Fuses are good. Had some diagnostics done at the local shop. No mention of cam position sensor. No codes
Old Feb 9, 2015 | 7:54 PM
does the crank sensor fit into a plastic cover for this engine? If yes is the cover deformed in any way?
Old Feb 12, 2015 | 4:48 AM
Maxmania64's Avatar
The cover is fine. Also replaced pcm.
Old Feb 13, 2015 | 7:00 AM
make sure the air gap is correct. if its to far back, no pulse will be generated. did you ohm check the sensor wires?
mamulan
Aug 20, 2014 8:39 AM
stdhawaii60
Dec 24, 2010 11:14 AM
catill
Aug 30, 2010 11:07 AM
rodentman
Sonic (Aveo)
Jul 5, 2005 11:37 PM
