No spark, and I can't figure out why. 87 Suburban 3/4t 4wd, 350
Old Feb 11, 2007 | 4:38 AM
rykoala's Avatar
Default No spark, and I can't figure out why. 87 Suburban 3/4t 4wd, 350
Howdy. As the subject suggests, I have a 1987 Suburban. I am currently having a no spark problem. I had the ignition module and the coil tested at autozone and they were fine. The coils is getting power (12v as tested with my cheap volt ohm meter. When I pulled the ignition module out, the connector for the pickup coil disintegrated in my fingers. I pulled the distributor and replaced the pickup coil and put it all back together. No go. So, on a whim I put a new coil in, since I've heard of coils testing ok but not being powerful enough to give a spark. Still no go.
At this point the only thing I can think of is that the wiring has a fault and while it is giving 12v there is not enough current to produce a spark. The only other thing I can think of is that the ignition module isn't triggering the coil correctly. I checked resistance on the cable that goes from the module to the coil.
ANY help is appreciated.
Old Feb 11, 2007 | 5:33 PM
golfer's Avatar
Default RE: No spark, and I can't figure out why. 87 Suburban 3/4t 4wd, 350
You had the ignitionmodule checked at Autozone ??? I certainly wouldn't trust them.
Is your vehicle carburated or injected ??
Old Feb 11, 2007 | 11:18 PM
rykoala's Avatar
You were right. The ignition module was indeed bad. An acquaintance of mine is a pro mechanic. I had him come over and scope everything out. The a/d converter in the module went out according to a technical reference he had. So, it runs now and because the timing is correct now it runs better than before.
xeqshnr
HHR
22
Feb 13, 2015 9:18 AM
jessejames
15
Nov 16, 2014 3:19 PM
Bradymurakami
Jan 31, 2014 4:55 PM
semper fi chevyguy
Aug 5, 2009 11:35 PM
g_gardner04
Jan 11, 2008 8:01 AM
