no start
Old Sep 26, 2018 | 4:21 PM
  #11
geo1's Avatar
When you check out sparky's,it gives you wire color,you can,with a dvom, check your 5v reference,when it shows low,you can disconnect each sensor mentioned,one by one to see if it's a bad sensor, voltage will come up,so key on for test of each, just don't plug any back in with key on,no spikes
Old Sep 26, 2018 | 4:24 PM
  #12
wa101's Avatar
Default No start
Ok, thanks
Old Sep 27, 2018 | 5:56 PM
  #13
wa101's Avatar
Default Still need help!!!!
I was going thru the sensors. Checking for 5 volts. And the FRP an APP had 2.21 volts. But after I unplugged EOP and I check the FRP and APP they had 5 volts. So do anyone thinks a bad EOP sensor would stop the truck from starting?
