no start
Old Sep 25, 2018 | 7:26 AM
wa101's Avatar
Default no start
I have a 2008 chevy suburban, last week reduced engine power showed up. I scan the truck and I got code P0641. there is no other codes. so I went to start the truck an it started for about 1 min. then it shut off on its own. and now it wont start back up. I replace the FSCM, I got it from GM FLASH. but its still not starting, I don't hear the fuel pump coming on.
Old Sep 26, 2018 | 10:33 AM
Kenny House's Avatar
Did you check the FSCM fuse in the panel in your engine compartment?
Old Sep 26, 2018 | 11:09 AM
wa101's Avatar
Default Still no start
Yes, and they where good...
Old Sep 26, 2018 | 11:14 AM
Good visually or did you check it with a meter or light? If it was visual just slap a known good one in there. If it doesn't fire the pump up and you already changed out the FSCM then it's most likely the pump. I replaced my pump from the top. I cut a hole out under the seat. I have yet to edit the "DIY" video for youtube.
Old Sep 26, 2018 | 12:12 PM
wa101's Avatar
Default No start
Yes, I check both ways. But I will change it out. And see what I get....
Old Sep 26, 2018 | 12:13 PM
Good luck!!
Old Sep 26, 2018 | 12:53 PM
geo1's Avatar
No luck with wiring check?
Old Sep 26, 2018 | 12:59 PM
I'm cautious suspecting the pump since there are so many variables in that circuit to make it power up. But it's leaning that way...... I assume it's a 2007 to 2014?
Old Sep 26, 2018 | 1:04 PM
geo1's Avatar
Yea,641 is 5v reference,with cam sensor involved,pump is 12v, different circuit,that sparky's answers.com is the solve to the problem,might not be exact in the fault area,but it's all there,wiring colors and sensors affected
Old Sep 26, 2018 | 4:07 PM
wa101's Avatar
Default No start
Well, no luck yet. I been going thru the wires. Trying to find something wrong, No luck. But I'm about to change the camshaft sensor, to see if it will make a difference. And i'm going to check out answers.com too. To see what info I get from there. And thanks for the help.
