no start
I have a 2008 chevy suburban, last week reduced engine power showed up. I scan the truck and I got code P0641. there is no other codes. so I went to start the truck an it started for about 1 min. then it shut off on its own. and now it wont start back up. I replace the FSCM, I got it from GM FLASH. but its still not starting, I don't hear the fuel pump coming on.
Good visually or did you check it with a meter or light? If it was visual just slap a known good one in there. If it doesn't fire the pump up and you already changed out the FSCM then it's most likely the pump. I replaced my pump from the top. I cut a hole out under the seat. I have yet to edit the "DIY" video for youtube.
Yea,641 is 5v reference,with cam sensor involved,pump is 12v, different circuit,that sparky's answers.com is the solve to the problem,might not be exact in the fault area,but it's all there,wiring colors and sensors affected
Well, no luck yet. I been going thru the wires. Trying to find something wrong, No luck. But I'm about to change the camshaft sensor, to see if it will make a difference. And i'm going to check out answers.com too. To see what info I get from there. And thanks for the help.
