No Start and no crank
Old Jun 22, 2013 | 4:42 PM
Sledgehammer's Avatar
Default No Start and no crank
Hi All
99 suburban 5.7l with 206 k miles 2wd
After 6 months of slow cranking , kinda like dead battery it finally has given in. All the lights still turn on properly and all electrical works fine.
She will not crank and all I hear is the click from the starter relay.
This happened overnight as before it (even slow) always started right up. It is an older truck so I do not wish to throw to much money at it any more ...
So what are my possibilities here:
Bad starter?
BAd battery?
My issue is that I have VERY limited supply of tools and work space.
What do you all suggest?
Old Jun 22, 2013 | 7:46 PM
Do the interior lites go out or get very dim when you try to start? If so, it's most likely battery, otherwise I'd get the starter & solenoid checked. First start w/ a fully charged battery.
Old Jun 23, 2013 | 12:38 AM
Hi shark,
Lights remain the same. dash Lights also remain on when turning the key in "crank " position so really nothing is happening. No security lights . only the very small click form the relay. Battery is good and everything worked fine when I parked her yesterday....kinda stumped right now
Old Jun 23, 2013 | 11:39 AM
Sounds like the starter or solenoid has gone Tango Uniform but first you need to check the battery connections to the solenoid. Also try tapping on the starter and then see if it will engage. If that works, then the starter is bad.
Old Jun 24, 2013 | 1:23 AM
replaced the starter All good now!
Thanks!!!
Old Jun 24, 2013 | 12:19 PM
That's great! Thanks for reporting back with your solution. It could help others in the future.
ebcrosby
Astro
Jan 15, 2014 6:52 AM
discnik
Aug 3, 2009 2:07 AM
aric272727
Feb 3, 2008 9:57 AM
thomas51
Nova & Chevy II
Dec 14, 2007 6:38 AM
phlyntstone
Dec 10, 2005 4:17 PM
