O2 Sensors
Old Sep 9, 2009 | 10:26 PM
bullet62's Avatar
Default O2 Sensors
Ok so I just put magnaflow exhaust on my 05 Suburban, and I took out the CATS. I knew it was gonna happen and it finally has the check engine light is now on. is there a sensor that sends out a false reading to the computer to take of the check engine light?
Old Sep 10, 2009 | 9:44 AM
myotherchevyisablazer's Avatar
well for the diesel's we can get a programmer(efi live)and can work with that particular situation,im not sure on a gasser though?
you might want to invest in one for your application.....really helps
Old Sep 10, 2009 | 8:35 PM
Put the cats and downstream O2 sensors in. Viola, lite's out. Of course you'll lose that 200 hp you gained by removing them.
Old Sep 10, 2009 | 10:08 PM
MDTAHOE's Avatar
Professional Mechanic
There is no sensor however there is a way to trick the computer. You need to get 4 spark plug non foulers from the auto part store. 2 per side. The are in the "help" section at the large chain stores. Drill the bottom out of all of them as big as you can without making the side walls to thin. Then screw 2 of them together. Next put your rear O2 sensor in the non fouler and put it back in the exhaust pipe. The computer checks to see if the cats are working by seeing a difference between the front and rear sensors. By installing the rear O2 in the non fouler you are pulling the sensor out of the stream of exhaust gas effectively making the readings between the front and rear sensor different.
swatson1
Feb 26, 2017 8:25 PM
RedBoat
Dec 20, 2007 10:52 PM
tahoe07
Dec 11, 2006 8:16 PM
av8rkirk
Nov 1, 2006 1:08 AM
smalltuck
Jan 24, 2006 11:32 AM
