Oil change..
Old Feb 11, 2007 | 10:10 PM
P_RsTahoe's Avatar
Default Oil change..
Well, I did my first oil change on my tahoe. It has 4400 miles and it still had 31% oil remaining. I've had it for about 6 months now so I decided to change the oil to put mobil 1. When I got under the truck I noticed that there was a drop of oil where the transmision meets the engine. There seems to be a little hole where the tranny meets the engine, it seems like its supposed to be there. Has anybody else noticed this?? I'll keep an eye on it to see if oil shows up again. Thanks..
Old Feb 11, 2007 | 10:20 PM
Default RE: Oil change..
Did my first at about 2K and didn't notice any leaks, but can't say I looked specifically where you are referring to. Since put in Mobil 1 also, will be awhile before I crawl under again unless I see something.
Old Feb 11, 2007 | 10:47 PM
shnormo's Avatar
Is it the torque converter drain access hole?
Old Feb 11, 2007 | 11:51 PM
P_RsTahoe's Avatar
Im not sure what it is or what's it called. It does seem like it belongs. Its in the bottom. Thanks.
Old Feb 12, 2007 | 12:12 AM
shnormo's Avatar
I'm going to say it's the torque converter drain plug.
Old Feb 12, 2007 | 1:15 AM
P_RsTahoe's Avatar
Should there be something covering it? Thanks.
Old Feb 12, 2007 | 1:52 AM
shnormo's Avatar
Well the torque conver is in the bell housing for the trans. There should be a small acess hole cover at the bottom that looks like a smashed LARGE smashed rivet.
Old Feb 12, 2007 | 11:13 AM
P_RsTahoe's Avatar
Ok, thats not it then. Its' where the tranny meets the engine. I follow the line and all the way in the bottom there is a tiny hole. Next time im under it Ill take a picture. Thanks..
Old Feb 12, 2007 | 12:56 PM
Hardin Thicke's Avatar
ORIGINAL: P_RsTahoe
I think that hole you're referring is to nothing more than a weep hole for a) water that has intruded after passing thru high water or b)for use as a telltale thatoil that is escaping thru the rear bearing. If it's ATF or motor oil, it shouldn't be leaking at 4400 miles. I'd get it looked at.
BTW, by saying that you had 31% oil remaining, are youindicatingthat only a quart and a half of oil was in the pan after draining it?
Old Feb 12, 2007 | 4:42 PM
dogpack3's Avatar
Pretty sure he ment oil life.
