Oil change..
Well, I did my first oil change on my tahoe. It has 4400 miles and it still had 31% oil remaining. I've had it for about 6 months now so I decided to change the oil to put mobil 1. When I got under the truck I noticed that there was a drop of oil where the transmision meets the engine. There seems to be a little hole where the tranny meets the engine, it seems like its supposed to be there. Has anybody else noticed this?? I'll keep an eye on it to see if oil shows up again. Thanks..
Did my first at about 2K and didn't notice any leaks, but can't say I looked specifically where you are referring to. Since put in Mobil 1 also, will be awhile before I crawl under again unless I see something.
Ok, thats not it then. Its' where the tranny meets the engine. I follow the line and all the way in the bottom there is a tiny hole. Next time im under it Ill take a picture. Thanks..
ORIGINAL: P_RsTahoe
BTW, by saying that you had 31% oil remaining, are youindicatingthat only a quart and a half of oil was in the pan after draining it?
