Oil Filter 2007 Tahoe
Old Dec 4, 2010 | 11:39 PM
Gunnywaldo's Avatar
Default Oil Filter 2007 Tahoe
I just did the oil change on my 2007 Tahoe and noticed that the only Filter available is the Short PF-48 filter.
I want to use the taller style filter but cant find a match, from what I can tell the metal ring in the filter is coded Z3 which should indicate the correct mounting thread.
Does anyone know of the part number for a TALL filter?
Old Dec 5, 2010 | 8:32 AM
nj85z28's Avatar
Senior Site Administrator
you can try a PF61 but from what I understand sometime around 07 GM changed to metric threads.
Old Dec 5, 2010 | 10:00 PM
From the trend of the last ten years, it appears that GM is trying to eliminate the oil filter as they keep getting smaller.
Old Dec 6, 2010 | 6:30 PM
Gunnywaldo's Avatar
Default Thanks
Thanks guys, I don't want to have to experiment too much by buying different filters I thought if someone knew first hand that would be great.
On my Sillouhette and astro it was straight forward a Fram 3980 was the tall version of the PF-52.
So are your sure on the PF-61 or is it a guess?
Thanks for your help.
Old Dec 7, 2010 | 7:05 AM
SabrToothSqrl's Avatar
Default filters
I agree; looking at that tiny thing you think, this can't be enough for this engine... but it's what they did so...
just be careful about putting something w/the wrong threads on there.
you could take a new/clean filter to a hardware store and find the matching bolt... then, spend $0.10 on that bolt... take it to the auto store and find a filter that fits it perfectly...
then your not risking f*ckn' up your engine oil filter threads....
Old Dec 7, 2010 | 8:13 PM
It seems like on my 97 Tahoe with the 5.7 the 4x4 used a different filter then the 2x drive. Do the 07 4x4 use a diff filter? if so then that would be the alternative...
Old Dec 7, 2010 | 9:07 PM
Not according to the look-up tables at the parts stores. Back in the day the old 350s used a smaller filter in the cars than the pickups.
Gunnywaldo: Be careful if you do find a bigger filter as there may be other differences such as bypass, etc. Not saying that there would be but could be differences.
Old Dec 9, 2010 | 9:37 AM
ousig2408's Avatar
why do you want to use the taller one? They designed it to work with the smaller filters so I am sure it is more than enough. It is funny that it is basically the exact same filter that I use on my '99 Acura TL...I use the Mobil 1 filters and synthetic oil (if anyone cares)
Old Dec 9, 2010 | 2:49 PM
Default shaft!
I thought that had sometihng to do with clearing the front drive shaft? i think the 4x4 one was smaller...
ChevyMecha
Spark
Apr 24, 2015 4:37 AM
DeHartShadow
Oct 22, 2013 10:52 AM
Injector
Feb 11, 2013 12:21 PM
Oxxon
Sonic (Aveo)
Mar 5, 2010 8:51 AM
trush
Jan 1, 2008 9:27 PM
