Oil leak
Old May 9, 2020 | 12:28 AM
sly92's Avatar
Default Oil leak
I have a 2003 z71 suburban 4wd, I recently replaced the valve cover gaskets and oil pressure switch due to small oil leaks. Now I have a very steady oil leak that was much worse than before doing gaskets and pressure switch. Any insight would be much appreciated.
Old May 9, 2020 | 10:07 AM
Cusser's Avatar
You should be able to determine whether the sender or which valve cover gasket is leaking oil. Clean off real well, do visible examination, use talcum powder or UV dye/goggles if necessary.
Old May 9, 2020 | 1:38 PM
Silverfox103's Avatar
You need to be more specific as to where the leak is, so we can better help.
Tom
Alex Recupero
Aug 19, 2021 11:37 AM
Stanley Fink
Sep 5, 2019 8:15 PM
BurbanMCS
Apr 20, 2013 12:38 AM
Sean1021
Aug 14, 2012 5:32 PM
ChevyChic
Oct 4, 2009 12:04 AM
