Oil Pressure
Old May 22, 2008 | 11:49 AM
spanky's Avatar
Default Oil Pressure
My oil pressure gauge is reading in between o and 20. obviously this is not right but is getting worse and worse. My mechanic said a while back that thicker oil is necessary with older vehicles. I tried that and it worked for some time. But now just lately when i start it up it makes a knocking sound. Any advice? thanks.
Old May 22, 2008 | 11:58 AM
V70tdi's Avatar
Default RE: Oil Pressure
The first thing i think about when i read your tread is thet you have some bearrings wearn out. Or if the oil pump has a pressure valve that has get stucked in open position.
Old May 22, 2008 | 12:10 PM
spanky's Avatar
it doesnt knock when i start going. only when i start it up and a little bit when stopped.
Old May 22, 2008 | 11:18 PM
Need to verify the gauge reading by temporarily adding a mechanical gauge. Is that the pressure at idle? Does it go up to about 40 psi at normal speeds?
Is it a hard knock or more like a ticking like a sticky lifter makes?
Old May 23, 2008 | 12:25 PM
spanky's Avatar
i brought it to the mechanic and he said it sounds like bad crankshaft bearings. So it looks like ill be selling it. Want it? Make an offer.
Old May 23, 2008 | 10:09 PM
RonH's Avatar
I had a car that was diagnosed with the same thing because of low oil pressure. Turns out it was only a stopped up oil pickup in the crankcase.
Steelman512
Jun 8, 2023 2:51 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Dallas4
Oct 23, 2012 1:45 PM
trolea1234
Mar 3, 2009 10:58 AM
