Oil pressure drops after warm up on 2007 5.3L Suburban
Old Mar 28, 2019 | 1:03 AM
coconino84103's Avatar
Default Oil pressure drops after warm up on 2007 5.3L Suburban, 128k
Oil pressure perfect until a few minutes after engine warms to 210 then drops from 55+ to 20 psi while cruising and then to under 5 psi at idle. I have replaced oil sending unit. No improvement. Then dropped the pan and replaced O-ring, screen and pressure relief valve. No improvement. Then replaced oil pump with high velocity pump and did increase oil pressure from 40 to 55+ psi but then engine warms to 210 and get the same pressure drop. Then went back in and replaced the camshaft thruster plate. No improvement. Last ditch attempt, changed back to conventional oil and put a nice KnN oil filter. No improvement!!! This engine runs so smooth, cannot figure out what’s going on Help!
Old Mar 28, 2019 | 1:30 AM
Engine has 128k
Old Mar 28, 2019 | 5:23 AM
SDfromSD's Avatar
Sub’d Curious if you get it resolved. Also check out GM-trucks.com if you haven’t already. Seems to be way more traffic at that forum.
Old Mar 28, 2019 | 6:57 AM
Not resolved yet, thx for the heads up on the gm truck site
Old Mar 28, 2019 | 8:56 AM
Cusser's Avatar
When you replaced the pressure sending unit did you also replace the cylindrical screen under that?
Have you tried a heaver-weight oil, wouldn't hurt with 128K miles, like a 10W-40 ?
We have 2005 Yukon 200K miles with fine actual oil pressure on the gauge, but occasionally get "oil pressure low" wording for a few seconds on the driver command screen, or whatever GM calls that. So since the engine has not self-destructed over the last 6 months, I believe the pressure gauge reading and just figure that the computer doesn't think oil pressure rises fast enough on start up so momentarily gives that error message. So on that I haven't done anything on that yet except change the oil and the brand of filter.
Old Mar 28, 2019 | 2:25 PM
They don't seem to have section for '07 'burbans.
Old Mar 28, 2019 | 2:50 PM
Cusser's Avatar
SDfromSD might mean trucks with same engine. For example, my 2005 Yukon Denali has the 6.0 engine, my 1994 Suburban had the 5.7 engine.
Old Mar 28, 2019 | 8:08 PM
Did you check the oil pressure with a mechanical gauge?
Old Mar 29, 2019 | 10:30 PM
Yes, please read the OP. Mechanical gauge, screen, O-ring, pressure relief valve, new pump (high velocity), and new camshaft thruster plate. Either done or replaced. Engine runs smooth as a top. Need something new here, please.
Old Apr 16, 2019 | 3:53 PM
Have now replaced the rod and main bearings and still has not resolved the problem
