Oil pressure fluctuation
Old Feb 23, 2015 | 12:43 PM
hwkchief's Avatar
Default Oil pressure fluctuation
I have a 2005 suburban and While driving my oil pressure guage will go to 0 and I get the warning dings and low oil Pressure read out on dash then guage will peg out at 80 for a bit drop to 0 peg back to 80 and will usually stay at 80 even at idle won't move. I am pretty sure oil pressure and pump are fine no problems with engine and oil level is good. Think it's probably the oil pressure sending unit or the guage in the ICU. Any ideas
Old Feb 23, 2015 | 8:44 PM
Mastermech's Avatar
Default Op erratic
You may very well have a defective stepper motor in your dash cluster (it drives the needle). This is a common failure. I suggest the vehicle be scanned to see what the OP really is. I suspect it's ok. If it is the dash cluster stepper motor, you ca get a rebuilt dash to cure the problem
Old Feb 24, 2015 | 9:26 AM
I moved your thread into the Tahoe/Suburban section for more views and to make it easier to find in the future.
Old Feb 24, 2015 | 1:26 PM
Scotiapilot's Avatar
Oil Pressure sending unit. Exactly what happened to mine. Drove me insane and caused me lots of worry.
When pressure sending units go out they typically peg it at 80 then they start to bounce around then fall etc... the final death of them is either pegged or they drop and the chime will drive you crazy.
When the stepper motor goes out it will typically read real pressure then begin to bounce around. etc.
YMMV
Old Feb 24, 2015 | 1:29 PM
Old Mar 8, 2015 | 8:57 PM
hwkchief's Avatar
Default fixed
Thanks for all the advice and ideas. Problem was the oil pressure sensor. Finally had a break in the weather to be able to change it And all is working OK now. Once again thanks.
Yogi
Feb 14, 2014 3:07 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
2007silerado
Mar 4, 2012 6:16 PM
Scany
Sep 11, 2008 3:10 AM
cblu007
Jul 26, 2007 8:11 PM
