oil pressure guage gradually falls to zero
Old Jan 29, 2010 | 1:52 AM
topofthetotem's Avatar
Question oil pressure guage gradually falls to zero
Hello everybody!
Please forgive me if this has been posted before.
I have a 2003 chevy suburban (a great vehicle BTW) but before the new year I noticed that my oil pressure gauge was showing that the pressure was dropping to Zero. ( I was generally driving 150-200 miles trips when this would happened)
So late December I sent my vehicle into the shop and got them to check it out and replace what needed to be replaced.
I was told that the oil pump was working fine and that the problem was the oil sending unit so they replaced it.
Fast forward a month and on my second 150-200 mile trip of the new year the oil pressure gauge does the same thing and drops to zero as I'm about twenty minutes away from home.
Has this happened to anyone before? and what could be the problem?
Any help would be greatly appreciated.
Lawrence
Old Jan 29, 2010 | 3:22 AM
mudmaniac's Avatar
Ride of the Month
May 2009
What motor do you have, how many miles are on it and what oil do you use?
Old Jan 29, 2010 | 1:25 PM
I have a 5.3L 285 hp V8
It has 123000 miles
I use a 5w/30 Quaker state (it gets to -30 degrees celsius regularly here in the winter)
Old Jan 29, 2010 | 4:20 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I assume that it's not consuming oil and that a low oil level is not the cause.
If the oil level is not the issue I still think it may be an issue with the sending unit or the gage. I recently added a mechanical oil pressure gage to mine so I know for sure.
Old Jan 29, 2010 | 5:57 PM
Yeah oil consumption is not a problem but I am over due for a oil change.
I should mention I did have the cluster repaired.
the86ali
Apr 19, 2015 8:07 AM
tootall
Mar 5, 2014 12:21 PM
nickt
Nov 5, 2010 10:52 AM
Eaton
Aug 15, 2009 10:57 PM
shanael1
Aug 30, 2008 5:14 PM
