Oil pressure low alarm
Old Nov 29, 2019 | 10:09 AM
Madison Dees's Avatar
Default Oil pressure low alarm
SOMEONE PLEASE TEL ME HOW TO TURN THE BROKEN OIL SENSOR ALARM OFF I CANT TAKE THE BEEPING ANYMORE AND I AM 10 HOURS AWAY FROM HOME AND I CANT WAIT A DAY TO FIX IT!!! I know my oil isn’t actually low its just a broken sensor. Does anyone have any other ideas besides me beating it with a bat. Please someone answer I’m 19 and I have no idea what to do... but I can’t take the beeping anymore
Old Nov 29, 2019 | 12:10 PM
oilcanhenry's Avatar
Pulling the proper fuse should shut down the alarm.
Old Nov 30, 2019 | 10:25 AM
Cusser's Avatar
Your photo shows 2000 rpm and no oil pressure on the gauge. Even though your oil level is OK, you may still be without any oil pressure and driving it will ruin your engine. So I'd check that out before driving.
Or it could just be a bad oil pressure sending unit, or wiring to that. But I wouldn't gamble.
Mrs. Cusser occasionally has that same oil pressure warning but it still reads fine/correct oil pressure on the gauge, but she does not get the "Stop Engine" warning like you show.
So I'd get that checked out and fixed as alternative to being cheap or stubborn and ruining the whole engine.
Old Nov 30, 2019 | 2:46 PM
He has a point. There might be plenty of oil in the pan, but the pump is sucking air through a broken seal.
Old Nov 30, 2019 | 6:17 PM
kevinkpk's Avatar
General question regarding an 03 5.3L suburban, oil pressure sensor. Mine is showing either pegged out or 80 on the gauge. Have a new sensor, this comes with a screen (small), cannot figure out where it goes?
Old Nov 30, 2019 | 6:22 PM
kevinkpk's Avatar
Old Nov 30, 2019 | 6:30 PM
kevinkpk's Avatar
Nice, now my pc is not responding.
Old Nov 30, 2019 | 6:48 PM
Cusser's Avatar
The screen goes underneath the sender. On my 2005 Yukon, the mechanic says my year/model does not have one, and recommended not to change the sender as long as the gauge works.
Old Nov 30, 2019 | 6:52 PM
kevinkpk's Avatar
Gauge is pegged or showing 80. I sent the cluster in this week due to speedometer malfunction. Shop said he swept the oil gauge twice, replaced to LVDT (stepper motor), also asked the same about the gauge being pegged or at 80. I have the sensor ready to go in, but was questioning the screen.
Old Nov 30, 2019 | 6:53 PM
kevinkpk's Avatar
Can't post a pix
