P0327 Fix
Old Nov 17, 2025 | 1:24 PM
ABburb4372's Avatar
Default P0327 Fix
Hello....New member here.
my 2001 Burb is giving me a P0327 code. there was an oil leak and inorder to narrow down the culprit I decided to degrease the engine bay and hose it off with water. I also replaced the valve cover gasket and when I took it for a drive after 25 miles or so, I am now getting a SES message and the code is P0327 bank 1. Here are my questions.
1. did my cleaning the engine had anything to do with this code?
2. considering this is a 25 year old vehicle, should I go ahead and replace both knock sensors, harness, intake manifold gasket and valley pan gasket.
3. or is there an easier fix.
Any help is appreciated.
Old Nov 17, 2025 | 7:52 PM
Cusser's Avatar
Originally Posted by ABburb4372
I decided to degrease the engine bay and hose it off with water..
I'd wait a few days, water could be present somewhere and causing the issue.
Ask me how I know this !!!
Old Nov 17, 2025 | 9:53 PM
ABburb4372's Avatar
How? Did you have the same issue?
Old Nov 19, 2025 | 8:38 AM
Cusser's Avatar
I've had check engine codes on other vehicles after cleaning the engine, had to wait for stuff to dry.
I've had the electric motor for an above-ground pool get wet during a rainstorm, and after two days of drying out, worked fine.
Old Dec 1, 2025 | 10:58 AM
ABburb4372's Avatar
I finally decided to replace the knock sensor. she is 25yrs old and I have never replaced the knock sensor. I knock sensor was all rusted and there was water in the hole. while I was at it I decided to replace the valley pan gasket, intake manifold gasket, clean all fuel injectors (I got a cleaning kit on Amazon) and clean the intake manifold of all carbon deposit. All these were original. I also thought of replacing the O ring on the crank shaft position sensor, instead of replacing the whole thing because a) the current one is working and b) it is expensive ($150 for AC Delco at the dealer). Here's my question - can I just replace the O ring. If so, where can I buy that. the dealer only sell the whole unit. Thanks in advance.
gafirefighter
Aug 21, 2024 4:48 PM
Skeeda
Jul 25, 2023 10:27 PM
CalDog
Silverado DIY and Useful Threads
Jun 10, 2017 11:21 PM
1985GREYGHOST
Mar 27, 2016 2:55 PM
firelance911
Mar 17, 2011 11:47 AM
