P0A45 drive motor "B" sensor circuit!
Old Apr 13, 2015 | 11:29 AM
08HybridHoe's Avatar
Angry P0A45 drive motor "B" sensor circuit!
I have looked every where for this damn thing. the one website that might have helped is under maintenance. So any help would be greatly appreciated.
Old Apr 5, 2022 | 6:36 PM
donjoe's Avatar
Default Same problem
Just did a motor swap on a 2015 Chevy 1500 5.3 cranks hood no start P0A4A code
drive motor B position sensor circuit over speed
Old Apr 6, 2022 | 1:12 PM
repairman54's Avatar
That looks like a code for a hybrid.
What is P0A45 CHEVROLET code meaning?
The drive motor generator position sensor is monitored by the motor control module. The motor control module monitors the angular position, speed and direction of the drive motor generator rotor based upon the signals of the resolver-type position sensor. The position sensor contains a drive coil, two driven coils and an irregular shaped metallic rotor. The metallic rotor is mechanically attached to the shaft of the drive motor generator. At vehicle ON, the motor control module outputs a 7 volt ac, 10 kHz excitation signal to the drive coil. The drive coil excitation signal creates a magnetic field surrounding the two driven coils and the irregular shaped rotor. The motor control module then monitors the two driven coil circuits for a return signal. The position of the irregular metallic rotor causes the magnetically-induced return signals of the driven coils to vary in size and shape. A comparison of the two driven coils signals allows the motor control module to determine the exact position, speed and direction of the drive motor generator rotor. The position sensor is a non-serviceable part of the drive motor generator.
Bigdiesel3500
Aug 17, 2022 12:07 AM
Govikes
Dec 5, 2021 1:57 PM
bumperking
May 10, 2015 2:26 PM
Ragman33
Oct 16, 2012 8:11 PM
lonewolf04
Nova & Chevy II
Nov 5, 2011 7:45 PM
