passenger brake light problem
Old Oct 13, 2009 | 6:53 PM
CodyB4C's Avatar
Default passenger brake light problem
I thought I should post this in here since I have a 1999 chevy 4x4 two door tahoe. Passenger brake/signal is not getting any power, all other lights work. Front turn signals, headlights, all running lights, both reverse lights and the drivers side brake/signal work. The passenger side turn signal blinks like the bulb is out but all the bulbs are good. I checked all the connectors up to the firewall and the passenger side brake/signal green wire wasnt showing any volts. All fuses are good. The problem is somewhere inside the cab.
Brake signal switch? But the other brake lights work
Multifunction turn signal switch? all other turn signals work including passenger front
Turn signal relays? all other turn signals work including passenger front
I dont know what it could be? Any ideas?
Old Oct 14, 2009 | 6:01 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Has to be a broken wire or bad connection somewhere.
Old Oct 14, 2009 | 7:20 AM
CodyB4C's Avatar
Can we rule out the multifunction switch since the driverside works?
Old Oct 14, 2009 | 7:42 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I think so because the front turn signal still works.
Old Oct 14, 2009 | 8:52 AM
CodyB4C's Avatar
Alright, I guess I will need to pull apart the dash. Does anybody know some good places to check for cut wires? Does the passenger side brake/signal wire stay dark green all the way to the multifunction switch?
Old Oct 14, 2009 | 11:19 PM
HoleInOne's Avatar
Check fuses first. There may be a seperate fuse for that. I know there are seperate fuses for trailer lights.
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
beckya99
Jul 12, 2011 12:29 PM
bad350trk
Jan 1, 2008 11:06 AM
digdug
Aug 2, 2007 10:53 PM
mike17
Astro
Apr 17, 2007 12:20 PM
