Please help
Old Nov 8, 2019 | 3:23 AM
Kvingxadamson18's Avatar
Default Please help
Hey guys I have a 2002 Tahoe 5.3 and I have a oil leak that I just can’t find I have had a mechanic replace the valve cover seals and I have changed the oil pan gasket twice still leaking so I had a mechanic look at it and he took the tranny out because I thought it was rear main he said it wasn’t so I took the part back doesnt look like it’s coming from the top of the engine I don’t know what else it could be please help could it still be the rear main that’s what I’m thinking
Old Nov 8, 2019 | 5:13 AM
oilcanhenry's Avatar
Scotty Kilmer, a mechanic in Texas uses a product that if supposed to make seals work much better if a leak develops. I have no idea if it really works, but it's far cheaper that a rear crankshaft seal replacement.It's called AT-205 Re-Seal. Its a watery substance that is made of some polymer substance. Here is a link to Amazon for it:
https://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM/ref=pd_cp_263_1/133-6913501-0309311?_encoding=UTF8&pd_rd_i=B000NVW1LM&pd_rd_r=86498f77-fdfd-46ac-a785-06ce518f982d&pd_rd_w=Okq4E&pd_rd_wg=kQlyP&pf_rd_p=0e5324e1-c848-4872-bbd5-5be6baedf80e&pf_rd_r=F4X1YS525FWC25J6VGMH&psc=1&refRID=F4X1YS525FWC25J6VGMH https://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM/ref=pd_cp_263_1/133-6913501-0309311?_encoding=UTF8&pd_rd_i=B000NVW1LM&pd_rd_r=86498f77-fdfd-46ac-a785-06ce518f982d&pd_rd_w=Okq4E&pd_rd_wg=kQlyP&pf_rd_p=0e5324e1-c848-4872-bbd5-5be6baedf80e&pf_rd_r=F4X1YS525FWC25J6VGMH&psc=1&refRID=F4X1YS525FWC25J6VGMH
Old Nov 8, 2019 | 7:47 AM
He should have changed the rear main seal with the transmission already out.
Old Nov 8, 2019 | 7:00 PM
Yeah, I agree. Still lots of independent mechanics out there that are barely capable of figuring such things out unfortunately..
Gal I was dating once, took her car to a "mechanic" using that term loosely in this case. Ran a code, P0300 on the readout.Lovely.
She got antsy, and took it to this guy, instead of allowing me to repair ir. Dude puts a set of cheap plugs in the engine and charges
her like they were Iridiums. Needless to say it wasn't the plugs, it was a bad coil pack. Replaced it, erased codes and good to go..
Miamifire41
Jul 7, 2014 7:03 AM
ccd
Jul 20, 2013 9:31 PM
krowe111
Jun 4, 2013 6:25 PM
hfdff
Aug 20, 2011 10:59 PM
bnk190
Mar 29, 2009 4:08 PM
