Power lock driver side will NOT stay locked when I press the lock button!
Old Jun 8, 2020 | 3:04 PM
Mike_T's Avatar
Default Power lock driver side will NOT stay locked when I press the lock button!
I just changed the driver side power window regulator w/ motor and thought everything was working, but then noticed this strange behavior with the door lock button.
Oddly though, if I press the lock button from the key fob, the driver side will stay locked.
What makes it even stranger is sometimes when I press the lock button from the door, it will chime or ding, almost like the sound when you forget to put your seat belt on. But usually if I press it again, it will lock, but of course it still always automatically unlocks itself. All the other doors are working fine.
Also, if I move the lock manually on the door, it will stay locked.
So it only seems to be when I use the lock button on the door that it keeps unlocking itself. The chime noise seems to only happen when I press the lock key from the door, though it has chimed sometimes from the key fob, but if I press it again, it will usually lock. This chiming sound really baffles me, I have no idea what or why it does this almost randomly when I press the lock button, even sometimes from the key fob.
Any ideas or suggestions?
Old Jan 19, 2025 | 4:32 PM
Mpeak31's Avatar
Default Issue resolved?
Hi Mike! I was curious if you found a solution to this? I am having the exact same issue after changing window regulator!!
Thanks
Monty
Travis Simpkins
Feb 2, 2020 9:16 PM
Legs
Apr 10, 2018 7:29 AM
Jack Pilley
Jun 23, 2017 4:59 PM
millerlls220
Oct 15, 2013 7:33 PM
VSTAHOE
Feb 27, 2007 6:04 PM
