power locks
Old Mar 21, 2007 | 5:23 PM
gmlover's Avatar
Default power locks
I have a 2000 Z71 Tahoe. Sometimes my locks will work and sometimes not. This effects all my doors. Can someone please tell me where the relays for the door locks are located? I looked in the engine compartment and the fuse panel. I'm just assuming this is my problem. I still herethe locks clicking when I move the switch to lock and unlock positions. It also does the samething when I use the remote. Thanks for your help.
Old Mar 21, 2007 | 6:28 PM
ZX1100F1's Avatar
Default RE: power locks
Sounds like the power door lock relay is bad to me as well.
The relay is mounted up under the instrument panel above the pedals on the driver side, it is a bit of a bugger to locate.
There are several relays under there the easiest way to find it is to hold your RKE transmsitter and hit the lock button while you are under neath the dash panel and listen for the relay to click.
Old Mar 25, 2007 | 11:25 AM
gmlover's Avatar
Thanks. I'll give that a try.
sidewayzpimpin
Jun 12, 2007 6:40 PM
disastro
Jul 26, 2006 9:09 PM
cookie
Jul 7, 2006 2:30 PM
