power steering pump
Old Nov 19, 2011 | 1:48 PM
shamrock246's Avatar
Default power steering pump
Are there any recomendations for a replacement power steering pump i did some front end work and put a remaned steering gear,new pitman arm,idler arm,and upper ball joints all AC/delco except for the gear box that was autozone reman but the steering is tighter than it was before and jacking up the front dosen't make much of a difference,i have no idea how old this pump is and thinking it just dosen't put out the pressure it once did
are the AC/DELCO remans any good?or should i just get a new one and is there a good site to get them from?
Old Nov 19, 2011 | 10:47 PM
MDTAHOE's Avatar
Professional Mechanic
Did this happen afterthe box was installed?
Old Nov 20, 2011 | 7:06 AM
yup i did everything at once, there was a difference in turning torgue between the old box and new on the bench i thought the old box was easier because it had a lot of miles on it looks to be original (257,000 miles) the fluid was very dark but was flushed out before the work was done
Old Nov 20, 2011 | 9:02 PM
MDTAHOE's Avatar
It is more than likely the problem is in the reman of the new box. I would not trust anything reman from Autozone
Old Nov 21, 2011 | 6:24 AM
your probably right i dont think they will give me my money back but just keep giving me a different box maybe the adjustment nut on the top will help on a different note Napa sells the whole pump EVO and all for about 130ish
w002mia
Mar 18, 2013 11:42 AM
hunter10220
May 18, 2011 8:37 PM
mrjonesnsa
Apr 29, 2007 1:57 AM
homer2nyce
Oct 5, 2006 2:21 AM
goose
Jul 3, 2006 3:29 PM
