Power Window problem Tahoe -00
Old Sep 26, 2006 | 8:13 PM
guitarplayer's Avatar
Default Power Window problem Tahoe -00
My rear left power window is suddenly out of order (the window is closed at this moment). When i push the power window button to open the window i can hear a "click" noise but nothing happens. If i push the button to close the window i have the same "click" noise as on the other doors when i push theirs button to close position when they are already closed.
The fuses seems ok and the power lock and the door light works ok.
Could it be the power window motor or some other fuse/fuses that i don't know about?
Best regards
Christer
Old Sep 26, 2006 | 8:46 PM
ZX1100F1's Avatar
Default RE: Power Window problem Tahoe -00
Sounds like the power window motor went tango uniform on you.
Old Sep 26, 2006 | 11:01 PM
sjenkinzz's Avatar
Had the same problems on my '01. The rear plug in came loose(how, I have no idea) and on the front motor, lost the ground someway.
Old Sep 27, 2006 | 1:52 AM
ZX1100F1's Avatar
ORIGINAL: sjenkinzz
And it made a "clicking" noise after the plug came lose???
Old Sep 27, 2006 | 7:33 AM
The "clicking" comes from the control button not from the motor, (and have the same sound on the other doors when i try to close a closed window).
I have power to the door as the powerlock and light works. I have loosen the wiring contact from the body and put on some contactspray and put it back but without any change.
There is a square bulb on the wiring rubber, could it be a fuse there?
Old Oct 3, 2007 | 5:47 AM
ChevyRidinHigh's Avatar
I have the same problem on 04 tahoe, after I installed a in-dash dvd player, i'm not sure if i blew a fuse or what, but neither the driver nor the passenger door have any power to the windows or locks, but the rear doors, the windows function on. I don't understand what the deal is? if anyone knows what may be the problem, can you please give me a solution, a.s.a.p oh and also in the gauge cluster nothing works but the speedometer and the rpm meter, all the others are all the way to the left, like says i have no gas... and some lights are on, like ABS .. Battery light... etc If anyone knows how i can fix this please let me now..Thanks =)
¤ Jonathan ¤
Old Feb 25, 2008 | 8:10 PM
Blue03xtreme's Avatar
ORIGINAL: guitarplayer
Best regards
Christer
Im experiencing the exact same thing right now. I noticed a few days ago my windows weren't responding when I tried to roll them down. Then after a few mins they rolled down fine. Today Im leaving work and try to roll them down, Nothing! Finally got passenger window to roll all the way down and up, pwr door locks work fine, pwr mirrors fine. Its only the Drivers window that wont roll down. Button clicks and clicks but does nothing. Took everything apart, checked all the wiring harnesses, everything was secure. I assumed my motor had gone bad but why did the passenger side do the same thing then start working fine. Is it just bad luck that both my motors went bad at the same time? Any info is appreciated.
justin69
Feb 28, 2015 2:54 PM
keith195558
Jul 11, 2014 11:22 AM
davbell22602
Mar 10, 2010 8:36 PM
Luca1
Aug 11, 2007 9:25 PM
