Problem with 96 Tahoe.........
Old Aug 17, 2007 | 9:27 PM
ramfootball36's Avatar
Default Problem with 96 Tahoe.........
I was driving home the other day and about 5 miles from home the car just shut down. Died in mid-stride. It had happened to me one month before and I thought it was the fuel pump. I replaced it, cleaned up the ground and threw a new fuel filter in. Then the exact same thing happened. The problem is the next day Icome back and it starts.This has happened both times.Where should I start? If there an ignition module or something that goes on these. AsI said, it is a 96 2 door with 165,000 on it. Help!
Old Sep 12, 2007 | 11:00 PM
Bringdanoisemik1's Avatar
Default RE: Problem with 96 Tahoe.........
I would start with cleaning the intake valve by removing the air intake tube and spraying some carb cleaner inside the valve.
Old Sep 12, 2007 | 11:35 PM
kotty's Avatar
Yeah, I agree with bringdanoisemik1..clean the intake valve and the Chevrolet Pickup Valve Cover through spraying some car cleaner.
Old Sep 12, 2007 | 11:39 PM
ORIGINAL: kotty
Not sure about the valve cover, but definitely the intake valve with "carb cleaner"
Rosariods
Jul 21, 2011 8:13 PM
BayAreaChevyGuy
Jan 6, 2011 2:27 AM
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
Yesi
Oct 8, 2006 6:27 AM
