Problem with a/c venting
I have a 04 suburban 1500 LT with the Dual Automatic Climate Control,no matter which button i push,all the air flows to the floor vents instead of the dash vents when i push the one for vent flow,could it be the climate controls or something else,any suggestions?
Your problem is probably the mode door actuator. They usually fail with age. They are plastic with plastic gears. It is located under the dash. There are different ones that look alike so make sure you get the correct one.
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
