Problem of suburban rear heater
Old Feb 26, 2013 | 9:16 AM
pascal_french's Avatar
Default Problem of suburban rear heater
Hello,
We have a problem with the rear heater suburban.
The air is not hot. I removed everything until you get back to the radiator. It heats well but one hose is cold. There are two pipes underneath the box that enters the radiator, one is hot and the other cold.
Of where this might come from?
Radiator clogged?
If this is the case, does it drain the water completely or not?
I hope I have been clear since the translator is not great.
Thank you for your answers.
cordially
Pascal
Suburban year 2000 LT
Old Feb 26, 2013 | 10:57 AM
Sounds like the rear heater core is clogged. It will have to be flushed. Sorry I am not familiar with the Suburban rear heaters.
Old Feb 26, 2013 | 11:44 AM
Thank you for your answer, this is what I feared.
I tried to remove the hose connections below the box but I can not do it ...
When I'm to change the coolant, I will take the time to disassemble everything and rinse thoroughly. But for this, I have found the coolant corresponding to suburban.
cordially
Pascal
Siberian
Sep 14, 2014 12:12 PM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
jrsavoie
Jun 17, 2010 1:17 PM
sxyryan
Feb 25, 2008 8:43 PM
mightymom400
Dec 2, 2006 5:47 PM
