Question for lowered tahoe owners..
Old Jul 20, 2007 | 12:13 PM
P_RsTahoe's Avatar
Default Question for lowered tahoe owners..
Hey, I lowered my 07 tahoe with the McGhaughys 2/3 about 6 months ago. Around 2 months ago it started making a rubbing/cracking noise when I turn the wheels completely to either side. Its coming from the front end somewhere but I cant pin point it. Has anybody else had this issue? Thanks..
Old Jul 20, 2007 | 3:24 PM
JTALAMBO's Avatar
Default RE: Question for lowered tahoe owners..
Do you have bigger rims? If so can it be the tires rubbing the inner plastic liner, just trim that a little.
Old Jul 20, 2007 | 3:34 PM
P_RsTahoe's Avatar
I have bigger rims but that isnt it. I have already done that. Its some king of metal to metal clunk. Thanks..
Old Jul 20, 2007 | 5:47 PM
e's Avatar
e
possible tie rods need a little lube
Old Jul 21, 2007 | 9:00 AM
P_RsTahoe's Avatar
Nobody else is having this issue? Im wondering if its because of the lowering or not? I just may take it in to the dealer. But Im sure they will blame it on the lowering kit.
Old Jul 21, 2007 | 10:56 AM
e's Avatar
e
can you duplicate the problem while its in the driveway? If so have someone get behind the wheel while trying to narrow down the noise. Does that kit use the control arms for the drop? Have you went back and re-tighten all the bolts? Have you lubed all of the joints lately.
Old Aug 7, 2007 | 1:41 AM
Odawg's Avatar
Rs,
I lowered my 99’ two door Tahoe and although it’s a different suspension set all together, if your bushings are not all lubed up your truck will make creaking noises when the suspension is articulating even the slightest bit.
Old Aug 7, 2007 | 6:50 PM
negra07's Avatar
only DJM uses control arms to lower the front of the tahoes.so it cant be his kit. he either used spindels or coils.
Old Aug 8, 2007 | 3:52 AM
uraijit's Avatar
2wd or 4wd? Spindles, or coils? Like others have said; everything lubed up good? Who did the install, and how long was the work warrantied for?
Old Aug 8, 2007 | 10:12 AM
freyguy's Avatar
Kinda sounds like the ABS grind. Does the ABS or traction control light come on? My wife's does during slow parking lot manuvers while turning. I think it's because I put too much stress on the rear abs lines when I replaced the springs. It's been discussed before and apparently the wires are very fragile and break easily, which can cause this issue.
